concrete expansion joints
merlvern | Posted in General Discussion on June 22, 2006 04:19am
another rookie concrete question.
i just had my driveway re-done with concrete. 40’x20’x4″……not an expansion joint in the whole thing. it’s my understanding that they are put in to essentially crack the concrete where you want it to.
am i screwed?…can they be “cut in” after the fact?
is my contractor a big ol’ dope?
thanks
  1. experienced | Jun 22, 2006 04:31pm | #1
    Yes they can be done after the fact. The quicker (like today) the better!!!
    CapnMac | Jun 22, 2006 04:48pm | #2
    am i screwed?
    That's a different question, on many levels.
    can they be "cut in" after the fact?
    Yes.  It's quick, if a bit messy; call the rtental center and get a rate for a wet concrete cutting saw.  Typically, a cut joint can be as shallow as 3/8".  Spacing them about the width of the concrete down the length works.
    is my contractor a big ol' dope?
    That could be an entire 'nuther thread all by its lonesome.
    In my neck of the woods, it's a bit tougher to get the concrete guys to remember to sleeve driveways than to get CJ put in; next hardest seems to be getting dowels put in across joints.
  3. FastEddie | Jun 22, 2006 05:31pm | #3
    Agreed, it can easily be done after the fact.  And it needs to be done quickly for two reasons: while the concrete is fresh and green it will cut easier, and you want to get the grooves cut before it starts to crack on it's own.
    1. merlvern | Jun 22, 2006 05:35pm | #4
      thanks everyone
      1. brownbagg | Jun 22, 2006 06:56pm | #5
        cut them today, about 10 feet apart, no more than ten feet and cut them deep. 1/4 the thickness of slab so at leats a inch deep. if you wait till weekend it be too late.
          CapnMac | Jun 22, 2006 07:22pm | #6
          Hmm, what happens if the reinforcing gets cut?  Doesn't that leave a "risk" that the edges will/could/might seperate?
          Ok, so it's low risk--the concrete 'dude' didn't joint (or ask about jointing)--so, there's (maybe) just 6x6 WWM smushed down to the bottom, but still . . .Occupational hazard of my occupation not being around (sorry Bubba)
          1. merlvern | Jun 22, 2006 07:59pm | #7
            i talked to my mason about the "joints" and he said that he is going to put in "relief cuts" today.......any advice/clarity about this? are they a common practice as opposed to the joints incorporated in a pour?thanks,john
            CapnMac | Jun 22, 2006 10:23pm | #8
            Well, that's what "we" have actually been talking about with the concrete saw.
            "Common" will depend some on location.  (Hint:  Update Profile <g>)
            I've seen more engineers specify relief cuts in large commercial slabs than I used to--but I don't know if it's a "trend" or not.
            There are two arguments for relief cutting.  One is that the weight is on the "top" side, so if the concrete "bends" at all, that top surface is in compression--the saw cuts can then "close" to relieve that stress (which likely cracks the concrete underneath, but in a neat line, not all jagged).
            The other argument is that a traditional control joint is messy, what with having dowels & the like in it, especially in a "hot" (versus cold) joint.  The thinking then goes, a messy joint will not be as clean as a neat joint, ergo if it cracks, the crack will not be neat, either.Occupational hazard of my occupation not being around (sorry Bubba)
          3. merlvern | Jun 22, 2006 10:56pm | #9
            thanks capn'note to self......in the future omit phrases such as "screwed" and "big ol' dope" from posts.2nd note to self.....check references, don't take comments like "i know a great mason" at face value.appreciate all your help
