Could anyone give me insight to the advantages/disadvantages to conditioning the crawl space and any requirements that would have to be met
The best tool for straight, splinter-free cuts is made even better without a cord.
Are you talking cooling only? Or heat as well?. My crawl space is heated. In the summer I leave the furnace fan on so it does get air circulation, although no a/c.
The advantage I see is the space would be less likely to have mold and moisture problems if it has air circulation. (Qualifier) My crawl space floor is cement. I would put down a layer of poly if the floor is dirt or gravel as the air will infiltrate the house and could cause a musty smell if not covered.
If the crawl space is open to the outdoors then I would allow a good cross ventilation making sure that unwanted critters and water/snow can't get in. Then insulate and vapour seal the floor above.
