In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Corner of my Basement
unclemike42 | Posted in General Discussion on February 20, 2021 05:32pm
Thought I would update my progress in my basement remodel.
My last post on this was after I had removed paneling and found a leaky cleanout fitting in the 3 inch ABS stack.
https://www.finehomebuilding.com/forum/support-for-3-inch-abs-riser
After that post, I decided to remove the framing that was cut-nailed into the CMU exterior basement wall, so I added some threaded rod I had laying around to hold up the pipe.
    unclemike42 | Feb 20, 2021 05:44pm | #1
    The block wall needed some help so I pulled of the framing which was ripped 2x, and used a grinder with a metal diamond blade to cut the nails that did not come out with the wood.
    I patched up and coated the block wall with fiber reinforced cement. The local big box stores supply was mostly bags of hardened, and I ended up with a couple different colors.
    unclemike42 | Feb 20, 2021 05:49pm | #2
    I put an inch and a half of XPS along the wall, followed by a stud wall to hold some rock wool.
    The bulkhead was extended to make room for an expansion tank required to go with a water pressure regulator. the overnight water pressure went to 120 PSI. I am pleased at how quiet the fixtures are at 50 PSI.
    1. calvin | Feb 20, 2021 06:43pm | #3
      Would you please post a picture of the not so “neat” part.
      That way to clean for a demo.
        unclemike42 | Feb 20, 2021 07:38pm | #4
        I have the luxury of working at my own pace, so try to pick things up before they get too out of control. Don't want to fix this up and end up in the hospital because I tripped over some extra stuff laying around.
        1. calvin | Feb 20, 2021 08:00pm | #5
          I left all my sites like that. Imposition on a customer is enough during a remodel. No need to remind them overnight.
          I want a pic of the 3/4 day, you know before you mop the floor.
          Which I used to do lightly when called for b/4 going home. Especially on a concrete floor.....a basement for example. Anywhere that was to be left “broom clean”.
          Living areas, ram board, cardboard, or paper taped down on hardwood or tile, drops over.....pulled, shook and folded.
          And always thinking of customer safety. No way ladders left up and open.
          I don’t think I left anybody pissed.
          Remodelers that save time ( $ to them ) give the trade a bad name.
            unclemike42 | Feb 21, 2021 12:21pm | #6
            There is also some selective framing in the pictures.
            I am working my way around the basement, so there is still too much stuff there, some unrelated to the remodel.
            Imagine that, too much stuff in the basement.
        2. calvin | Feb 21, 2021 01:15pm | #7
          That’s more like it.
          It what I saw many times when asked to look at the job.....
The Fine Homebuilding Interview: Emily Mottram
A Maine architect speaks about Pretty Good House and biophilic design principles that adapt to all climates.
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
  • Get Stunning Views With Folding Glass Doors
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Step-by-Step Install Prehung Exterior Doors
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
