looking for a chart of all or any angles that you may encounter with installing crown moulding, saw it in a book once, that showed all miter and/or bevel cuts for any wall angle, but cannot find this reference,if someone could point me in the direction I need that would be great.
http://www.dewalt.com/us/articles/article.asp?Site=woodworking&ID=2
If everything seems to be going well, you've obviously overlooked something.
thanks thats what I needed
pita .. nice to see your friendly face.. hope all is welll with you and yours..
thanks for the link.. i emailed it to my offcieMike Smith Rhode Island : Design / Build / Repair / Restore
Eh, close enough. Et tu?
I'm still here, just lurking more than posting lately.If everything seems to be going well, you've obviously overlooked something.
A fellow named Joseph Fusco has a really useful on-line calculator for determining mitre and bevel angles.
It saved my sanity once.
http://www.josephfusco.com/FHB/crownscript.html
Check it out....
checked it out,and thanks again guys!
just keep in mind.....unless your trim is too tall to cut "not flat"
"upside down and backwards".....
you'll genarally get a better fit and have an easier time of it buy coping the inside corners.
The "easier time" comes after your do a coupla practice copes and get the hang if it, of course.
appreciate your input, the crown we are using is over 6.5 inches, yes it is laid flat on the scms.the upside down and backwards is understood, coping not a problem. I simply was looking for the ref. material so I did not need to use the sc.calc.everytime. a quick look at the tables, a quick adj. on the saw and done.
