cultured stone over exterior plywood
I have to adhere cultured stone to the perimeter foundation of the house I’m building. I plan to double-paper over the plywood shear walls, staple on expanded metal lath, and trowel on a coat of mortar for a substrate before the “stone” is applied. I expect I’ll also have to trowel mortar on to the concrete back a couple feet where the concrete stops and plywood shear walls begin to avoid an abrupt step-out line. How thick should the mortar be on the expanded lath over the plywood, and what sort of fastenings should hold the lath to the plywood?
You may want to post your question on the Breaktime forum; more construction-types frequent that site.
