Does anyone know if there are blades available for jigsaws to cut cement fiber siding? We have been using a zip tool and boy does it not work well at all. Thanks for any and all responses.
Dustin
Dustin
The best tool for straight, splinter-free cuts is made even better without a cord.
there was a prior posting about this and i think the result was, if you had to use a jig saw over say the shears or FC circular saw, go with carbide, if you opt for regular blades buy them bulk....
Sorry, should have clarified. We have shears and a tile saw with masonry blade, but for fine cutouts, like following the contours of crown molding, etc., I was looking for something to cut a bit better than that cursed zip tool. I read somewhere that abrasive blades work so tomorrow I'll give that a try. Any more info shoot it my way, and thanks for responding so quickly.
We have the same problem. I found some tungsten carbide jig saw blades that work pretty good. Only problem is they are $4 each. They are made by Remington. Regular blades are dull by the end of the cut. We also had good luck with a dozuki. One of those japanese trim saws. Someone should invent a tool just for this perpose. I like the FC siding but it is a mo fo to cut!
a 4" grinder works for a lot of tricky cuts too...
99% of our cutting is with a makita fibercement saw & a fein auto vacMike Smith Rhode Island : Design / Build / Repair / Restore
Are you using a quarter inch carbide bit in the zip saw?
Regards,
Tim Ruttan
