Hey guys,
I’m going to make my first laminate top for a customers bar. What do I use to cut the laminate to rough size? The stuff comes in a 30″x144″ sheet. Share your wisdom with me please.
Hey guys,
Come for craft beer and a panel discussion! Friday, March 28, 3PM-5PM at Booth 727 The event will feature a casual panel discussion featuring some of the crew that helped…
To get it down to a rough size, table saw works, so does a carbide scribe, or a jigsaw. Take your pick.
I tried a pick, it just made big holes. I need better aim.Spheramid Enterprises Architectural Woodworks
You gonna play that thing?
http://www.youtube.com/watch?v=32Ln-SpJsy0
it's not your aimit's all in the wrists
Barry E-Remodeler
he meant toothpick. Carbide tipped of course.
To just break the sheet down to rough size, you can use a decent pair of duckbill tin snips. Don't cut all the way to the tip of the snips, just nibble ahead a little at a time. Watch out for your knuckles on the sharp edges. Make sure you leave enough extra since the shears may fracture the plastic back 1/4" or so. There are special laminate shears that are handy to have in the tool box.
http://www.amazon.com/MA72500-Klenk-Straight-Laminate-Shear/dp/B000QFPD4W/ref=pd_sim_hi_1
Strips for edges and backsplashes are often cut with a slitter, table saw or router. On a table saw, you may need to add a sacrificial fence so the laminate can't slip underneath the fence. It usually helps to raise the blade higher. A 1/4" straight bit in a router is a very clean way to make a cut. It's used when mitering corners. Two sheets are brought together, a straight edge is clamped to guide the router and hold the sheets from moving. The bit cuts both sheets at the same time for a perfect match. It helps if you have a piece of plywood, MDF or similar to act as a backer, to clamp the laminate to and also allow the bit to cut into a little. It's always a good idea to have the PL well supported when cutting, same with the waste end too.
I've used those laminate shears for the past 20 years. Great for one off jobs. for production work TS is my choice.
Didn't have enough overhead room for the pick in my old shop :)
for rough sizing I always use one of those handheld hook-shaped thingy's with the carbide tip. A few passes along a straightedge, then just bend and the laminate snaps along the scribed line.
