Cutting stainless steel
trimtellect | Posted in Tools for Home Building on November 25, 2008 04:46am
Does anyone have any experience cutting stainless steel with a circular saw, and where may I purchase a blade for this task?
    observer | Nov 25, 2008 04:57am | #1
    Zip disc and a 4 1/2 or 5" angle grinder is what I use.
    PeteDraganic | Nov 25, 2008 07:48am | #2
    Never did stainless but have had great success with a carbide blade cutting brass and aluminum.
    I would be afraid that SS is too hard... I know it is no fun to drill.
    Cuts easy with a torch though.
    I refuse to accept that there are limitations to what we can accomplish.        Pete Draganic
    Take life as a test and shoot for a better score each day.          Matt Garcia
    1. McMark | Nov 25, 2008 04:28pm | #6
      What kind of torch?  Not an oxy-actylene,  that just melts and drips stainless.
        PeteDraganic | Nov 25, 2008 04:56pm | #8
        yes, oxy-acetylene.  I didn't say it was precision cutting.  welding it with a torch is pretty easy too.
        A plasma cutter does a great job for cutting stainless nice and clean.
        1. timothale | Nov 25, 2008 05:01pm | #10
          A lot of alloys of stainless steel will heat harden. especially when trying to drill holes.  be carefull not to add too much heat when working with stainless.
  3. aworkinprogress | Nov 25, 2008 08:08am | #3
    It really depends preciesly on what thickness you might wish to cut
    There will be some problems with using a standard saw with the RPM that it will have most likely.
    A specific saw and blade are available to cut various metals One company that makes such an item is M K Morse
    I have cut thin gauge Stainless with a jigsaw and a good Bosch 36 Tpi blade
    1. aworkinprogress | Nov 25, 2008 08:13am | #4
      The blade company is Japanese Tenru I believe They make a variety of great blades
  4. gfretwell | Nov 25, 2008 08:58am | #5
    I have an old 7.25" Sears circular saw I have relegated to cutting concrete and such. The other day I had some 22 and 20ga stainless I needed to cut up and it worked great with a 7" metal cutoff wheel. Using the fence or a guide board I was able to make some nice straight cuts. I am skinning a cabinet that has a stainless door (cut down stainless refrigerator door) for my outside kitchen. The other material was an old backsplash from a bar sink that has a nice 90 degree lip. I also cut 2 of the 3 tubs of the sink off to make a hand sink with the built in drain shelf.
    My circular saw made all those cuts just fine. It seems a lot better than a side grinder for controllability and safety from flying stuff. Still wear your face shield !!!
  5. Piffin | Nov 25, 2008 04:44pm | #7
    What is the end use of this SS?
    heating it with torch or friction cutting will destroy its desirable properties
      PeteDraganic | Nov 25, 2008 04:58pm | #9
      heating with a torch does nothing negative to stainless steel.  I've torch welded restaurant equipment without even discoloration (any discoloration buffs right out).
Wiring for Subpanels: The Right Cables
When running cable to a subpanel for a home addition, pay attention to the size of the wire and the amperage of the breaker.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
