Cutting wall tile in place
| Posted in General Discussion on December 27, 2003 06:30am
Hello
We are redoing our kitchen and replacing the counter tops with granite.  The existing counter tops are 5/8″ and the granite will be 1 1/4″.  Since we have tile back splashs, we need to cut 5/8″ off the back splashs so that the granite will fit in.  I would like to do it in place and I do not have extra tiles.  Someone suggested using an angle grinder with a diamond blade.   Will this work??  Also,  how do I do the interior corners??  I thought that this must be a common issue since plumber routinely have to cut wall tile in bathrooms, etc.
Texasron1
  1. steve | Dec 27, 2003 06:42pm | #1
    not an easy prospect, i assume you cant remove the required tiles, cut them and replace them
    a small circular tile cutter would work, the battery operated water tile saw from makita would work okay and keep down the dust, or a regular grinder with a dry diamond blade would also work with a lot of fine dust and noise though, either method, watch the depth. a scrap of wood ontop of the old countertop to mimic the new height would keep your cut straight
    into the corners would be a problem however, maybe  you could very carefully remove those two  tiles and cut and replace them
    if not, a series of small holes along the cut line (diamond bit) and very carefully break them off. you could drill these holes using a guide of some kind to keep the line straight
    caulking is not a piece of trim
  2. DaveRicheson | Dec 27, 2003 08:14pm | #2
    I use a dry cut diamond blade on a 4 1/2 inch angle grinder to cut access panels in tiled plumbing chase walls. Most of these are CMU walls, so we cut through both the tile and the block. To keep the dust down a little we hold the nozzel of the shop vac hose next to the grinder while we are cutting. When you get to the corner, just let the cut go deeper and get both sides at the same time. You will end up with about an inch to  inch and a half of each tile that is not cut. We finish those out with a dremel tool that has a flex shaft and diamond bur bit.
    Take you time. Those angle grinders can jump out of the cut if you try to go to deep at one time. Shallow cut=control=good job.
    Dave
  3. andybuildz | Dec 27, 2003 09:14pm | #3
    My small (3"?)Makita cordless with a tile blade has always worked great for me!
    Be well
            andy
    My life is my practice!
  4. john | Dec 27, 2003 10:01pm | #4
    The tiles in the corners sound like a job for the Fein Multimaster
    John
    1. goss2mn | Dec 28, 2003 05:45am | #7
      I'm currently cleaning up 1/16" grout joints in 2" square mosaic tiles with a Dremel grout removal attachment.  It's quite labourious.  Would you recommend the Fein tool for this?   What I am cleaning out is thin-set that has squeezed out into the grout joints.
  5. archyII | Dec 28, 2003 03:25am | #5
    You might try a rotozip with a tile bit.  I used one to cut in a threshold in a slate tile floor by using a guide strip.  Plunge cut into the waste and move up to the guide.
  6. geob21 | Dec 28, 2003 04:12am | #6
    So if I understand this correctly, someone installed a 5/8" thick counter top? Made of what?
    I'm having trouble with the fact that someone would cut corners enough to install a 5/8" top and not also have gone way cheap on the cabinets. If the cabinets aren't top shelf why bother with granite? Perfume on a pig.
  7. toast953 | Dec 28, 2003 07:22am | #8
    However you decide to cut that tile, I will suggest that you leave yourself a little wiggle room. If it was mine, 5/8" exsisting top, with 3/4" "new" cut= 1"3/8".  I know that you have actually measured the New Granite top, for it's thickness,, right,,,,. What happens if you decide to lower your base cabinets, will your drawer's clear, dishwasher,stove etc. Anywho, if it were mine, I would want to take a close at the Base cabinets, with the exsisting tops off, regardless if I was going up or down. Good luck Jim J
Tall Deck on a Sloped Lot
When deck posts exceed what the prescriptive code tables allow, it's time to consult a structural engineer for post sizing and possible bracing.
  • Sharp-Blade Solution
