I have a panasonic 12 volt 15 minute recharge [EQ ?]battery drill. The charger died, quick flash and done. Anyone have a portable Panasonic drill that has died that would like to sell a charger ?
Chris, Take the charger apart. My 9.6 v Sears drill charger died, and from prior experience with transformers, I knew there was a fuse inside. 1.5 or 2 amp, about 1 1/2 inches long. Replacements are available from Radio Shack. I'll bet you can fix it.
*They also have a diode inside, and a good tool repair outfit shouls be able to repair it cheap.
*Thanks ... already took it apart ... it wasn't the fuse, I checked that ... and nothing else "obvious"
*Could be the diode but good tool repair shops in the Northeast Kingdom of Vermont are few and far between .... maybe Burlington. Thanks
