Dimmer Switches and Flickering Lights
Photog | Posted in General Discussion on July 28, 2003 05:10am
I have a couple of light fixtures that very rarely get used. They happen to be controlled by a dimmer switch. The fixtures, the switch, and the wiring are all less than 1 year old.
I switched the lights on recently for the first time in several (3, 4?) months, and noticed that they flickered slightly for the first 30 seconds or so and then functioned normally thereafter.
Is it normal (or at least nothing to be concerned about) when lights controlled by a dimmer flicker a bit after a long period of inactivity?
TIA.
  1. JohnSprung | Jul 29, 2003 12:54am | #1
    Are these incandescent or flourescent?  If incandescent, try running the dimmer up and down quickly a few times to clean out the potentiometer.  If flourescent, be grateful that dimming works at all.
    -- J.S.
    1. Photog | Jul 29, 2003 03:44pm | #2
      Thanks John!
      These are in fact incandescent. I'll give your suggestion a try.
      Thanks again!
The Trump Administration Wants to Eliminate the Energy Star Program
The end of this program will likely lead to higher energy bills and fewer business opportunities for the American people.
