Garage floor has red clay dirt on it in several spots. Pressure washing
does not effect it at all. Scraping w/ a sharp blade works, however it is a
3 car garage. Without using a harsh acid is there any other cleaner in conjunction
with a pressure washer that might work.
What size pressure washer? If its that big a deal, you could rent a 3Kpsi or bigger at the local rental yard.
What about a scraper on a long handle w/ a 6 or 8" blade - I think you could cover a lot of ground in a hurry.
Or just give up and clay the rest...
Givehim 6 ?
The most I ever got was - oh never mind
Anyway, I was thinking that onje of those ice chippers on a long handle would work fine, especially if you sharpened it with a file or grinder. That would be much easier on your back and knees.
