DIY Spray Foam Help
mdifabio | Posted in Energy, Heating & Insulation on February 20, 2008 11:39am
Does anyone know of any good and economical diy closed cell spray insulation kits.  I want to insulate my current attic, which I am going to make into a functional upstair with a full shed dormer off the back.  I priced a few insulation contractors and it was $4,500-$6,000.  If I can do it myself, I would like to save the labor money.
Any insights would be greatly appreciated.
  1. Hiker | Feb 21, 2008 12:24am | #1
    I have done the math on a couple of vendors.  Even the bulk kits are not cost effective if you need more than 2 or 3 units relative to an installer.
    Bruce
  2. reinvent | Feb 21, 2008 01:41am | #2
    Here you go:
    http://www.rhhfoamsystems.com/
    http://www.tigerfoam.com/?gclid=CMD7sZespo8CFRFSagodWlt5Rw
    If you decide to DIY it get yourself one of those one piece tyvek suits with a hood and a respirator.
  3. sandalboy | Feb 21, 2008 02:03am | #3
    I've been wanting a DIY setup also. My projects usually are too small to pay someone else to come in. I've asked a couple times here and had limited responses about this. This kit listed on ebay... http://cgi.ebay.com/Spray-Foam-Insulation-Urethane-Foam_W0QQitemZ180215152918QQihZ008QQcategoryZ63894QQssPageNameZWDVWQQrdZ1QQcmdZViewItem seems like the best bet, and the best price per board foot. Unfortunately nobody here has replied whether they've used it before. Since it uses external compressed air, I would think that it is consistent from beginning to end of each cartridge. Where the Tiger Foam type, I would think would get weaker as the cartridge pressure goes down. If you go this route please let me know how it works out.
    Edited 2/20/2008 6:06 pm ET by sandalboy
    1. reinvent | Feb 21, 2008 03:03am | #4
      Only three grand what a bargin!
      1. sandalboy | Feb 21, 2008 04:31am | #8
        "Only three grand what a bargin!"
        Well yes, a relative bargain. Works out to 75 cents a board foot vs. 1.10 to 1.50 for the Fomo / Tigerfoam type kits.
        Ofcourse if you have one project using all of the stuff at one time, calling somone in would make more sense. On the other hand, if this covers 5 to 20 smaller projects, this way cheaper than a specialist.
        1. MAsprayfoam | Mar 01, 2008 06:12pm | #9
          I want all the guys doing the figurin' with the Tiger foam to come work for me please. Your rate is zero an hour correct? Seriously, usually the min rate to come do a job is $1000 to $1500. Less is like getting an excavation company to dig a hole for your mail box post.I've never talked to a DIY person doing a SECOND large foam job themselves!
    McDesign | Feb 21, 2008 03:07am | #5
    Don't know - I couldn't make the numbers work, on a pretty big attic (the "Attic Recovery" thread).  I used a sort-of Mooney wall arrangement; lots cheaper and works very well, says the client.
  5. dockelly | Feb 21, 2008 03:57am | #6
    Price seems kind of high, how thick is the foam? I got a price of 2.25 per sq ft for 2 1/2 thick foam. That would be roof and floor over crawl space, walls would be 2" thick at 1.85 per sq ft.
    Kevin
  6. GRCourter | Feb 21, 2008 04:22am | #7
    Tigerfoam, $630 for 600 board feet, don't know where you are located so I don't know how much you are looking for, R-7 per inch and then you can put a layer of Astro-Foil on the inside next to the foam for another R-7.  2" foam + foil and you have R-21 when you are heating, something in excess of that when you are cooling.
    Edited 2/20/2008 8:25 pm ET by GRCourter
Wiring for Subpanels: The Right Cables
When running cable to a subpanel for a home addition, pay attention to the size of the wire and the amperage of the breaker.
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
