Not basement wall, not in snow area, just block walls completely filled with concrete. outside is a stucco finish without the foam backing.
Understand lumens, ceiling brightness, beam spread, tilt, and color options to make a wise choice on a common fixture that can range from $75 to $750 or more.
Johnnie,
The walls on the house I'm building were poured solid and they appeared "moist" and wet to the touch for about two weeks after the pour. I think it was a slow curing in the high Florida humidity until the concrete reached the 27 day cure time.
I waited until after they appeared dry to do any furring, drywall, etc. and haven't had any trouble with them.
Hope this helps.
Mike
*I filled mine three week ago yesterday, I,m just think if I have to paint the inside with sometype of elastic paint sealer
