Door hardware
| Posted in General Discussion on November 17, 2006 08:25am
Hello All,
I recently bid on a  project to build and entry door and the customer gave me the go ahead. That’s the good part, the bad part is I did not fully resolve the design before I bid. The door is basically a 32″ entry door but he wants it to be split down the middle vertically and be hinged on both halves. The trouble is I am not able to find suitable hardware to keep the doors together when closed. What I need is a slide bolt that is disengaged when you turn the lock set and is spring loaded so that all he has to do is pull the door shut to engage. Standard slide bolts will not work because this door is the main door that they use and being that each door is only 16″ wide both doors would have to be opened each time they enter or leave. Any ideas?
Thanks,
Tom
  1. nycarpenter | Nov 17, 2006 08:31pm | #1
    What the???? Scotty, one crazy customer to beam up.
    1. G Hepplewhite | Nov 17, 2006 08:40pm | #2
      Its not something that I would want in my house.  He wants the 2 doors because of space constraints. I am a little worried because I have a feeling that he will not be happy with the arrangment after I am done. I did try to talk him out of it though and gave him a few different ideas to ponder. Oh well.
      Tom
      1. wane | Nov 17, 2006 09:01pm | #3
        Pella windows and doors has some sort of set up for this on their ???, what did they call them, garden doors, french doors .. check with them ..
        Edited 11/17/2006 1:03 pm ET by wane
      2. nycarpenter | Nov 20, 2006 05:18am | #5
        It just sounds like a major mess on every level- fabrication, weather stripping, security, function, and last but not least architecture.  He/she is doing to end up with those swinging doors you see on saloons in a old western. Don't forget that the opening will be at least 3" smaller because you will have two doors swinging into the house instead of a standard single door (1 1/2").
        1. G Hepplewhite | Nov 20, 2006 04:27pm | #7
          I agree. Luckily I am not too concerned about making a weather tight seal, the door opens into an enclosed conditioned porch. I have found a source for the hardware so thanks to all who led me in the right direction. I am going to try and walk the client through the cons of this arrangement one more time before I start on this phase of the work that he wants me to do. I would like the money but I know that this job will bite me.
          Thanks,
          Tom
  2. doorboy | Nov 17, 2006 09:36pm | #4
    Hager automatic flushbolts. 291D check them out at http://www.hagerhinge.com
    When the active door is closed, they engage. When the active door is open, they disengage. It's a good piece of hardware.
  3. Piffin | Nov 20, 2006 05:47am | #6
    That is too smallto be pratical for a double door setup, but an "Automatic" door bolt or door lock is what that is called
Fine Homebuilding – April/May 2023, Issue #314
Find online articles on options for countertops, wood-boring bits, ductless heat pumps, tighter miters, fences, and much more.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
