Hello,
I live in a very old house.Its be a fix me up on a small budget reading and doing as much on my own.i wantedto paint the kitchen but my walls had a formica or laminate panel.The cabinet door have a layer of panel on a door .Its like having a door glued to a door can i pull these apart.I hate my kitchen the top panel has lost its color. please can someone help me .Go Mooregreen
Edited 11/7/2007 10:35 pm ET by mooregreen
If you really hate what you have, then go ahead and experiment with breaking it down. How much worse can it get?
Read your profile, looks like this is your 1st post, welcome aboard. I think it will be tough to pull glued laminate off the the door, what's the inside of the door look like? Can you reverse the doors?
Ok, now I see that it might be laminate. That can sometimes be successfully loosened by ironing the formica with a hot clothes iron. But then you end up with a plywood panel covered in old glue."Put your creed in your deed." Emerson
Hey Eddie,edit your post moregreen asked the question, not me.
