double pane windows foggin up inside
shavano | Posted in General Discussion on October 13, 2005 07:45am
Looks like moisture found it’s way into my double paned window. I left my French doors leaning against an outside wall. They got rained on and now it appears condensation is forming between the two panes of glass. Been fogged up now for weeks afterward. Any suggestions on how I can fix this or do I have to replace the whole window? Thanks much in advance for any help!
  1. Mark | Oct 13, 2005 08:21am | #1
    You have to replace the glass portion of it.  If it's new then it will be covered under warranty.  For that matter,  most window companys have at least a 5 year warranty against the double glazing losing it's seal.
    " If I were a carpenter"
  2. junkhound | Oct 13, 2005 01:00pm | #2
    AH!  My favorite subject !
    Have slit the glass off tempered windows and cleaned them and reassembled with butyl or silicone.  Regular glass no luck, as the etcheing, (yes, enzyme etching) not simply 'fog' destroys the surface.
    In own dwellings, would never again install double pane glass (woule use storm windows or detachable sealed 2nd pane), even though I'll likely die before the 20 year 'fer sure' leakage and etching starts.
    edit caps and bold
    Edited 10/13/2005 6:01 am ET by junkhound
    1. JohnSprung | Oct 13, 2005 10:28pm | #3
      My favorite, too:  The old European idea, casement windows with both inswing and outswing sash in the same jamb.  It works in Oslo, Stockholm, and Moscow, and has for hundreds of years.
      -- J.S.
        jocobe | Oct 14, 2005 01:26am | #4
        You guys are funny.....there's nothing wrong with insulated glass manufactured by a reputable company. Andersen has very high quality glass.There's a local company here that'll make insulated glass with a one year warranty....now that I could understand as being less then desireable.There's usually a reason the glass fails. Either something got on it (chlorine or muriatic acid) or there is weight bearing on it that shifts the glass seal.View Image
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
