Dressing out new brick
mwgaines | Posted in General Discussion on February 23, 2007 04:43am
Got all the old brick removed. New windows and replacement brick on the way. After the new brick is installed, I’ll need to provide for hose bibs, exterior receptacles, meter base, tubing for the split heat pump, etc. Is there a “preferred” way to plan for these installations when dealing with brick veneer?
For instance, I’ve been told that most AC contractors just tell the masons to place a length of PVC through the brick where the heat pump will be located to provide for the plumbing. I’d sure hate to spend so much on rebricking and then have to detail it with a tacky setup like that. Is there a better way, or am I just being too much of a perfectionist?
Thanks,
Michael
PS. Any recommendations on vents or crawlspace doors?
New knowledge is priceless.
Used knowledge is even more valuable.
  1. dedubya | Feb 23, 2007 05:14pm | #1
    Mike ,The crawl space vents will either have a flange that will fit on the outside of the brickopening, or if its like the last ones I did last summer they had no flange just attached with mas. screws into the existing openings then I mortared around the openings- get the flanged ones of you can--  The openings for the ac. units , I use a dryer vent hood as I hate to see naked cable,copper line entering a opening also, I don,t see why they couldn't use a large enough elec. conduit. but then again I,m not a a.c. guy
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
