In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Drip edge cutting help
ncproperties | Posted in Construction Techniques on August 24, 2009 04:57am
For the life of me the simplest task is holding me up and when I get the answer I all ready know I’m gonna feel dumber.
Can someone walk me through or have a picture of how to correctly cut/ run/overlap/ the drip edge at a pitch change from a 12/12 to a 4/12?
    Sphere | Aug 24, 2009 05:04am | #1
    Run the 4 roof part up to the 12 and leave it sq. cut. Bring the end of the 12 down and cut off the roof nail surface back about 2", leave the face alone.  Lay it on and make a plumb cut on the face but bend the overhang lip to lap the 4/12 and the roof nail flange will butt or slightly lap.
    Clear as mud?
    "If Brains was lard, you couldn't grease much of a pan"
    Jed Clampitt
    1. ncproperties | Aug 24, 2009 05:16am | #2
      Yup, as I predicted I do in deed feel much dumber. As usual in my faults, I was trying to make things way more complicated than need be. You ought to see the 2' of drip I sacrificed into little 3" pieces of origami trying to picture how it should work out. Stretching to see any of the surrounding houses' roof lines for an example. As my boss said last week; "When you've been doing things for so long, you forget just how many ways it could be done wrong." I think I found every possible wrong way to do it on this one, until your answer. Thanks so much.
        Sphere | Aug 24, 2009 05:22am | #3
        I got spoiled working with copper so much, if ya really screw up, you can just solder on a new hunk and start over (G)Spheramid Enterprises Architectural Woodworks
        Matt | Aug 25, 2009 02:34am | #4
        Don't feel alone... I've found drip edge not the easiest thing to work.   It's hard to make roof corners look good too.
Fastener System for Solving Deck Fascia Board Expansion
A special drill bit and color-matched fasteners lets composite or PVC deck fascia boards expand and contract to minimize warping.
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
  • Get Stunning Views With Folding Glass Doors
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Step-by-Step Install Prehung Exterior Doors
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
