Drywall sander attachment
| Posted in General Discussion on January 4, 2000 11:49am
Does anyone have any experience with a drywall sander attachment for a shop vac? The kind that uses a 5 gallon bucket with water in it as a filter. Where can I gat one?
  1. Guest_ | Dec 02, 1999 02:51am | #1
    I have tried one bought from Home Depot for $20. My only complaint is that the corrugated hose makes a nasty whistling sound while the vacuum is on. Even after adjusting their "vent" that is supposed to stop the whistle.
    Also, if the vacuum suction is too strong the sanding shoe tends to stick hard to the spackle, causing the sanding screen to leave lines in the spackle and to scuff the drywall paper surface.
    After getting better at spackling, I haven't had much need for heavy sanding especially since I switched to the lighter spackle ( ie SHEETROCK® Lightweight All Purpose Joint Compound Ready-Mixed). I find less of a need to do more than a very light sanding with 220 grit sandpaper.
    Just MHO. Good luck,
    Phil
  2. Jim_Liston | Jan 04, 2000 11:49pm | #2
Tall Deck on a Sloped Lot
When deck posts exceed what the prescriptive code tables allow, it's time to consult a structural engineer for post sizing and possible bracing.
Start your subscription today and save up to 81%
