Drywallers- remodel taping question
peedee | Posted in General Discussion on June 2, 2009 05:43am
I’ve done some taping and mudding and I’m working with a gentleman who seems to have more experience than myself, yet he is suggesting on a remodel where new srock butts up into an existing (textured) ceiling to butt-tape i.e. run the tape up _to_ the ceiling but not lap it as in a standard wall-ceiling detail. It seems from my knowledge and experience this doesn’t accomplish the ‘bridging’ (?) that’s intended from taping corners. I’d like to hear some more experienced opinions on this, is it done? Is it acceptable (under the circumstances)? Is he blowing smoke?
Thanks,
David
  1. calvin | Jun 02, 2009 05:50am | #1
    I've done a variation on popcorn textured ceilings.  Flat taped some, used tearaway "L" bead on others.  The tearaway allowed easy trowling along and just below the popcorn.  Bead of caulk after tearing away and it's looked good ever since.
    If there's movement it's bound to open up.
    When doing crown I've gauged the crown location on the ceiling and scraped away the popcorn from there to the wall edge.
    Now, if it's not popcorn I'd be real tempted to corner tape it and match/blend texture.
    http://www.quittintime.com/
    1. peedee | Jun 02, 2009 04:45pm | #4
      No, it's not popcorn, rather light-knockdown. Thanks for all the experiential replies. One question I still have however is regards to the 'bridging' function of tape on seams. Doesn't it serve a purpose other than just to close the gap in the corner (not even getting into fire and air-infiltration, hypothetically)? Flat tape and caulk would of course make my life a little easier (not trying to match existing texture) but how often do these types of joints open up (given particularly given this is an old house with some newer framing lumber).
      Thanks again,
      David
      1. YesMaam27577 | Jun 02, 2009 05:51pm | #5
        Tape helps to prevent cracks. But only when it bridges a gap between boards of rock (like in a corner).
        Politics is the antithesis of problem solving.
  2. ruffmike | Jun 02, 2009 06:44am | #2
    I'm with Calvin, if it ain't popcorn the corner should be taped and finished, unless you are making the walls smooth and not messing with the texture. In that case a flat tape and caulk might be okay.
                                Mike
        Small wheel turn by the fire and rod, big wheel turn by the grace of god.
  3. drozer | Jun 02, 2009 03:17pm | #3
    if you decide to butt tape it, try using painter's tape to keep mud off the ceiling. and sand with one of those angled sponge blocks. and caulk.
    on popcorn, i have scraped away the popcorn with a 6" knife and corner taped with a 4", leaving a decorative border around the room. assuming the rooms not too big, and you're repainting the ceiling.
    if it's texture, i've used j-trim and caulk. and once, in a rental, i corner taped over the texture, so the border was built up/(down? lol). it looked ok, but was a pita.
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
