Dual voltage receptacle
davidmeiland | Posted in Energy, Heating & Insulation on March 10, 2008 12:15pm
Take a look at this link:
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=8120&section=10928
In my shop, I need to plug in a 3HP Delta Unisaw (it has a 20A, 240V cord cap factory installed, with a ground pin and two flat, horizontal blades) and a 1-1/2 HP Penn State dust collector (which has a household cord cap factory installed). I want to plug these two into the same duplex receptacle, which will go into a floor box that is right below and behind the saw in a perfect spot.
The item in the link seems like it might fit the bill, but it is rated for 2HP and not 3.
I could feed the receptacle from either one breaker or two.
Whaddya know about this?
    BillHartmann | Mar 10, 2008 02:15am | #1
    Looking at the Levition industrial catalog it appears that ALL 20 amp 250V receptacles are speced at 2 hp and 20amp 125v at 1 hp.
    To get 3 hp rating you need to go to 30 amp, 3 phase or 50, single phase 250.
    It appears that they are all the same regardless of the configuration. Locking, straight, simplex, duplex, commercial grade, hospital grade, industrial grade. I think that it isa NEMA or UL rating.
    I know that there are hundreds of thousand of 1 1/2 hp motor run on 15amp, 125 plugs. That is the way that all contractors saws are shipped and most still used in that configuration.
    And likewise many 3hp motors 20 amp/250.
    I am not 100% sure, but I think that those ratings for for use as DISCONNECT where you would pull the plug with the motor RUNNING.
  2. DaveRicheson | Mar 12, 2008 01:25pm | #2
    I don't put much stock in hp ratings on eguipment. It is mostly sales hype.
    I have a Delta Unisaw. Same hype.
    More important is the 240v/20a name plate information. I've been running mine on a dedicated 240v/20a circuite for 18-19 years now. No problems, ever.
5 Lessons from Building in a Cold Climate
A high-performance contractor shares the challenges of building in the cold Alaskan climate.
  • Use a Press Tool for Plumbing Connections
  • Remodeling Around Electrical Panels
  • Podcast 567: Soundproofing, Garage Doors, and Rotted Balconies
  • Podcast 567: Members-only Aftershow — Andrew Zoellner’s House
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
