Electric conduit thru garage wall quest.
TKanzler | Posted in Construction Techniques on August 5, 2003 05:13am
I need to get a 14/3/G NM cable from the basement into the attic, via an interior garage wall.  The problem is that I can’t get to the top of the wall in the attic, so running it inside the wall cavity is not practical.  Is is acceptable to use 1/2″ EMT inside the garage (from basement, through the rim joist and sheetrock, pull elbow or LB, against wall in garage and through ceiliing, with NM fittings both ends), or is there a problem with the fire rating of the wall and ceiling (IBC used here)?
Be seeing you…
    IMERC | Aug 05, 2003 06:38pm | #1
    3/4 EMT and LB's would be easier. Fire caulk where the conduit passes thru the rock. Put a pull bushing on the terminal ends of your stubs.
New House, Old Shell
A full gut remodel brought new life to an 1821 home that had undergone several misguided renovations.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
