In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
electric in concrete?
cutter | Posted in General Discussion on May 3, 2003 07:32am
I am putting together a permenent shop in a 30×40 building.question is…setting up table saw/router table in middle of floor(concrete).I have an expantion joint under edge of table.1 1/4 in deep x 1/4 wide with a foam filler strip close to the top and a caulked sealer on top.Can i clean crack out run seperate 12 guage wires (220 & 120 volt) through ,re foam & caulk to run pwr to saw & router without wires hanging down or running across floor ?  Thanks in advance. Scott
  1. Wet_Head | May 03, 2003 07:47pm | #1
    scary!
    Gunner | May 04, 2003 01:55am | #2
    NO.
       The wire needs to be in conduit. The expansion joint will expand and contract and rub the insulation off and maybe kill you. Probably not but anytime I think of electrical problems charcoaled bodies spring into my mind. If you have a lot of energy jack hammer a trough across and run the wire in pvc if you don't, learn live with an extension chord.
    Who Dares Wins.
    1. FastEddie1 | May 04, 2003 02:11am | #3
      Don't need a jackhammer, use a diamond blade or masonry blade and cut a trench.  Bigger issue is thrying to get it in the right place so it matches the shop layout for the next dozen years...or six months which ever comes first.
      Do it right, or do it twice.
        Gunner | May 04, 2003 02:17am | #4
        Yea I should have said that. I had cutting the trench with a saw and popping it up with an electric jack hammer in my mind. My fingers just didn't get the memo.Who Dares Wins.
          RichBeckman | May 04, 2003 03:01am | #5
          "My fingers just didn't get the memo."
          I hope your not using the postal service for those messages.
          Rich Beckman
          Another day, another tool.
          1. cutter | May 04, 2003 03:15pm | #6
            Thanks, I guess I'll have to go rent a concrete saw.I was hopeing to get off easy. SGB
          2. stonefever | May 04, 2003 03:48pm | #7
            Can you drop the service down from above?  Like on some retractable reel?
            Like Wet Head indicates, it would be less scary (and dangerous) should you spill your beer.
Forming Foundation Walls
In the first episode of FHB House Kansas, Travis and Joe of Catalyst Construction walk through details of their foundation walls.
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
