Electric On Demand Water Heater
CAGIV | Posted in General Discussion on November 16, 2006 09:53am
We are looking at a project to finish a space above a detached garage.  The company constructed the garage structure itself roughly 15 years ago.
The space will contain a kitchen sink and a bathroom.  No dishwasher, the bathroom will contain a shower.  The space will see minimal use as a guest suite for relatives and also serve as a media room for the homeowners on occasion.  Taking the minimal use into consideration I’d like to stay away from a standard tank water heater
A gas line to the structure would be cost prohibitive, at least at this point, though it may be the only option..  So, I need to find an electric on demand unit with one problem.   My plumber said he is going to research it however the only unit he know’s of that has a flow rate high enough to service a shower  requires three 30amp breakers and I don’t have that kind of power.   I can’t remember the current service how ever I am assuming 200 AMP The garage currently has a 100 AMP sub-panel in it.  I’ll confirm that when I am over there with the plumber next week showing him the job.
suggestions?
    BillHartmann | Nov 16, 2006 07:30pm | #1
    Check on the acutal flow rate needed.
    I have never looked at the specs, but I think that there are small ones available.
    One shower (just don't remove the low flow insert) is all you need to support at one time.
    johnnyd | Nov 16, 2006 10:39pm | #2
    Poor man's solution, which does require a bit of "maintenance" is to install a conventional tank electric heater, keep it drained until the day before your guests arrive...or even an hour before you need to use the shower, then fill it up and switch the power to it.  Turn it off and drain it after they leave. Have to make sure, of course, that no one ever misunderstands and turns power on before fillup.
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
