In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Electrical question
yojimbo2 | Posted in General Discussion on August 25, 2009 06:51am
There is a compressor with the following info on it:
Single phase
208/230
12 amp
The compressor has 12 gauge wire coming out of it, with a black/hot, white/neutral, and a ground.
In order to properly wire this compressor, you would need a 15amp double pole breaker at the panel, and run 12/3 romex from the panel to the compressor. Both the white and black wires would be hot, there is no neutral, but there is a ground.
Would this be the proper way to wire this device?
  1. DaveRicheson | Aug 25, 2009 07:27pm | #1
    Just run 12/2 wg and marrk both ends of the white wire with black or red electrical tape.
    Install a double pole 20 amp breaker for the #12 wire.
    Be sure to install a 240v cord plug and  receptical so that know one can mistakenly plug a 120v appilance into it..
    1. yojimbo2 | Aug 26, 2009 06:43pm | #3
      Yeah, I meant a double pole 20amp breaker. Thanks for the reply.
  2. JTC1 | Aug 25, 2009 10:22pm | #2
    Yes, DaveRicheson has already filled in the finer points.
    12/3 is a waste of wire (unless you already have it) - if you use it, just leave the white conductor disconnected and capped at both ends.
    Jim
    Edited 8/25/2009 3:24 pm ET by JTC1
Using Liquid Flash at a Wall-to-Foundation Connection
Brian Pontolilo demonstrates how to air-seal where the concrete foundation, mudsill, and ZIP System sheathing all meet.
  • Podcast 487: Cedar Closets, Conditioning a Woodshop, and Regional Construction Jargon
  • Podcast 487: Members-only Aftershow
  • Festool's Domino: Worth the Dough?
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
