Is there is standard way to detail under a exterior door threshold? I have an outside deck. The deck is 7″ below the door threshold. I have clapboard siding. Curious what material is used under the threshold??
Production manager Ian Schwandt explains how financial tools such as QuickBooks or Buildertrend can help companies track project costs for a healthy outcome.
If the threshold extends over the siding, just use the clapboard. Otherwisw, you'll probably need to use something (metal?) that won't get beat up by the traffic thru the door.
I drove around and looked at houses. Brick houses use a concrete threshold. I notice very few houses that use wood and vinyl have the same detail. It seems the material under the door would function as a kick plate. Still wondering
In my experience, a threshold that overhangs the siding by 1/2", or so, reduces (or eliminates) the need for a "kick plate". The closer the edge of the threshold is to the siding, the greater the need for a "kick plate".
I found the threshold extends out a bit. I used a piece of plastic 2x decking as trim, secured in place and provided support for the edge of the threshold which IMO undergoes a LOT of stress as people place the arch of their foot on that corner as they step through the doorway.
".......people place the arch of their foot on that corner as they step through the doorway."They do?? Most people I watch (adults, anyway) step completely over a threshold. - lol
Maybe not. I figure if I have to step up AND in ... I tend to use the arch of my foot on the corner. I'd bet that is where most stressing occurs ... dunno, tho ... never sat and watched people to observe their habits in this regard.
I've been using a piece of Azek for the kickboard under a doorsill. Usually 5/4', but 3/4" works if there isn't a lot of sill overhang.
It's rot proof, holds up well to getting kicked, doesn't need painting if you like white, or paints well if you want another color.
I make it the width from the outside of door casing on both sides. That way, the lines of the casing carry straight down. I like to pry it up just a little bit when I nail it, to help support the doorsill.
I almost always use 2x Trex. It makes a perfect sill support.
