Hi,
I’ve just finished reading an article by Gary Striegler about constructing frame-and-panel doors using a three layer sandwich technique (From Fine Homebuilding 145, pp. 98-101, “A Different Approach to Frame-and-Panel Doors”). I like the idea but is it suitable for the construction of exterior doors? Any comments would really be appreciated.
http://www.taunton.com/finehomebuilding/how-to/articles/different-approach-frame-panel-door.aspx?
Thanks in advance,
RonanC
Edited 3/7/2007 10:12 pm ET by RonanC
Ronan
We built several doors with that method.
Here is a set of double doors that are 2 1/2" thick, on these we used 5 layers, same method just two more layers. These doors have been in for about 6 years and are still fine.
On these cypress doors I used the three layer method, works fine.
I didnt read the link but when I build them that way I build the layers like a face frame for a cabinet, pocket screw it together. If the pocket screws will be in the way of anything I take them out before glueing up, otherwise I just leave them in.
The doors in that first pic are SWEET!
Forrest - envious
Doug,
Thanks for your reply. Your doors look great. That first one is amazing. This is my first time constructing a door. This pocket screw/sandwich system just seems so easy. By the way what type of wood do you like to use for exterior paint grade doors?
Thanks again,
Ronan
Ronan
I've built exterior doors out of walnut - yes paint grade, medX (the exterior MDF), cypress, which makes for a light weight door.
You can get some of the sappy walnut fairly cheap and its a good paint grade wood. Mahogany paints up real good to.
How easy is it for you to find locking hardware for those thicker doors?
Once I looked for hardware for a 3" door for over a year. Never could find it.
Pete
I dont think it was all that difficult to get the hardware, I'd have to check on the maker but I'm sure it was readily available - well not at True Value though!
I can find out the brand name tomarrow if you'd like.
