Hello all — Im still brainstorming my new house. xterior mdf is unheard of in these parts but I’m still looking. I need to wrap some porch columns and case out the porch beam with something (WITHOUT ANY KNOTS) What about AC fir plywood? any other suggestions? Thanks again! Charles Elkins
Use MDO or also known as sign board. Takes paint well and is made for exterior and interior use. Don't use MDF unless you want to replace it every month.
*... and don't use softwood plywood under any circumstances ...Wrapped porch columns usually take a beating and can open up at the corners if not detailed properly. What's wrong with white pine if you are less than 11 1/4"? If you're painting and using #2 SWP use BIN on the knots before priming (some here like 1-2-3 better, BIN isn't technically rated for exterior use).Jeff
One or two manufacturers do make an exterior-grade MDF, but the MDO is a better product for the application you mentioned.
Choicetrim/Primetrim. You can get it up to 11-1/4 I think.
*Charles,What's wrong with wood? Honduran Mahogany with a mitred lock joint will make a great post that will last for years.Ed. Williams
Hello all -- Im still brainstorming my new house. xterior mdf is unheard of in these parts but I'm still looking. I need to wrap some porch columns and case out the porch beam with something (WITHOUT ANY KNOTS) What about AC fir plywood? any other suggestions? Thanks again! Charles Elkins
