Exterior tile in a freezing climate
I am rebuilding an exterior, tiled balcony over a heated, insulated living space. The previous deck, built without an overhang, leaked through the cracked grout onto the siding. I plan to rebuild the deck with 3/4 inch CDX, a 3 inch overhang, drip edge and an EPDM rubber membrane. Is there a thinset/mastic I can use directly over the rubber membrane? Should I use an uncoupling membrane? What type of mortar and grout is suitable for tile exposed to rain, snow and frequent freeze/thaw cycles?
Edited 3/13/2008 11:37 pm ET by Tilenovice
Greetings Tile,
As a first time poster Welcome to Breaktime.
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
In the event you fail to receive the information you requested you may be able to find it in the archive listing of old threads on Breaktime.
If you scroll up in the upper left corner of your screen there is an advanced search function
that upon clicking will take you to a page of instructions directing you to previous threads dealing with whatever you type in the search bar which is found on that page.
If you type in 'outdoor tile', 'freezing tile', or other keywords of the subject matter you'll get a supply of data from those old threads.
Cheers
Peach full,
easy feelin'.
You also may find reading in the John Bridge tile forum advantageous.
http://www.johnbridge.com/vbulletin/index.php
Get a Peach full,
easy feelin'.
Both the substrate and the setting bed have to be sloped. Water will migrate to through the grout onto the setting bed and into the setting bed, and will freeze and crack.Dirt
Sand
Sloped Substrate (concrete or deck mud) quarter inch per foot
Membrane
Drainage Mate (troba or gravel)
Sloped Setting Bed (deck mud)
TileRegards, Scooter"I may be drunk, but you're crazy, and I'll be sober tomorrow." WC Fields, "Its a Gift" 1934
Even with all that, I just don't have any confidence that it will work. Bob's next test date: 12/10/07
http://www.schluter.com/2080.aspx
call and talk to these folks about their products to get a rec for the one you want
