Fan speed control switch question.
I have a fanlight that is switched by a switsh leg (one cable in the switch box).
I want to dim the lights.
I know I can’t put the fan on a dimmer.
My question is: Will a fan speed control switch also work as a dimmer or do I need to take the fan down and separately feed the fan and lights.
Thanx in advance.
Mr T
Do not try this at home!
Seperate feeds / seperate switches. Best way
there is a unit at HD to do just what you want ask in the electric dept.
You can get a remote that will control fan speed and light dimming. Not real cheap but affordable. A small receiver mounts in fan housing and depending on style either a wall mount or hand held transmitter. Put it by all the other manly remote controls.
