In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Faucet Mystery
lockmiter | Posted in General Discussion on September 15, 2009 02:19am
Hello All,
I just ran new supply lines from the sink cabinet base up tp my faucet so I could add a supply for a dishwasher. The dishwasher is not hooked up yet (no time for electrical work) I put ball valves on each supply. Most of the joints are soldered but I used sharkbite fittings to attach the new work to the old. I also replaced the sprayer nozzel (just had to screw it on to the old nipple).
Now, when I turn off the faucet it continues to run for a second as if it is draining whatever water is left in the line. It did not do this before I put the new work in. Hopefully someone out there can solve this. Thanks in advance for any suggestions.
  1. wane | Sep 15, 2009 03:15pm | #1
    sprayer have a one way valve on the line?, where does it connect to? sounds like it is draining through the faucet ..
    McDesign | Sep 15, 2009 03:38pm | #2
    Some sprayer nozzles (and shower heads) have a little check valve (often just a rubber flap) to prevent the dribble when the water is turned off.
  3. DanH | Sep 15, 2009 03:47pm | #3
    How much water? If it's just the water draining out of the spout, then any minor change, even cleaning off some of the hard water deposits on the spout, could have provoked this behavior.
    Is the behavior a problem?
    As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
    1. lockmiter | Sep 15, 2009 11:35pm | #4
      Not a problem just a nuisance, and a waste of water. Would it be worth taking the faucet apart and replacing all the washers?
      1. DanH | Sep 16, 2009 01:28am | #5
        Probably if you sat and watched the faucet for half an hour (before this change in behavior), the water would have come running out after several minutes.
      2. barmil | Sep 16, 2009 04:25am | #6
        A waste of water? Probably less than having the faucet on for a second or two when brushing your teeth. I think this isn't a real problem. BTW, all of my faucets drain a little bit after being shut off, particularly the shower, since I trap some water in its system when I close the valve.
  4. brucet9 | Sep 16, 2009 05:53am | #7
    Have you used the sprayer yet? Air in the nozzle end of the sprayer hose could be expanding and pushing water back out of the faucet spout.
    BruceT
    1. lockmiter | Sep 16, 2009 02:10pm | #8
      Good thought, I'll try running the sprayer and check to make sure all the connections are tight.
      1. Piffin | Sep 16, 2009 02:49pm | #9
        come back with a report. I've seen this a time or two and curious about the answer.
Industry-First Cordless Rebar Cutter and Bender
A brushless motor and 36v batteries power Metabo HPT’s cordless rebar bender and cutter.
  • Podcast 484: PRO TALK With Color Consultant Paula Gaull
  • Using Liquid Flash at a Wall-to-Foundation Connection
  • Forming Foundation Walls
  • Track Lighting for Functional Ambiance in Busy Spaces
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
