Anyone used both of these? Is the Supercut worth the extra $?
With the right approach, you can restore old hardware—whether through soaking, scrubbing, or polishing—giving it a fresh look while preserving its original charm.
I have the supercut.
it is more powerful and built for continuous use.
it has a hex arbor which holds the attachments more securely.
for all normal professional uses, virtually any of the less expensive varients will work fine.
fein will be including the hex arbor on all models later this
year. i do think the hex arbor is an advantage.
I wouldn't wait for it, though, as the machines utility is a tremendous
advantage. the supercut is $600 or therabouts in the carpenter's
kit form.
