You might check out this link to an article by Paul Fisette: http://www.umass.edu/bmatwt/Alternative_Trim.html It provides a good analysis of trim options. There is also a link at the bottom of the article where you can pose your question to Mr. Fisette directly on the website.
Out here in the NW we are waiting for Hardie to come out with 7/8″ Harditrim. Apparently that product has been introduced to the SW market, but they are not selling it in the NW – for some reason…
Has anyone ever used MG-Trim from MacMillan Bloedel Building Materials. I'm doing a bid on relacing failed wood composite trim that was used with Hardy Plank. Five years later Hardy PLank is doing fine but the trim is a disaster. MG-Trim is what is being offered by my local lumber yard in the fiber cement tim line. Looking to hear both pro's & con's about the product.
*It's all about price...If your customer can afford it...then use it...It will last as long as the siding right?near the stream,aj
*AJ, While price is always a concern in any proposal, I'm more concern about the product itself. I've been replacing wood composite trim for the pass several with 2x cedar milled down to 5/4. The MG-Trim is actually cheaper than cedar. This proposal is for a repeat customer, a good repeat customer. Do the work, turn in the bill, get paid, no queations. I would like to keep it that way. With any new product, I try to do my homework before I turn in my asignment. Thanks for the response.
*You might check out this link to an article by Paul Fisette: http://www.umass.edu/bmatwt/Alternative_Trim.html It provides a good analysis of trim options. There is also a link at the bottom of the article where you can pose your question to Mr. Fisette directly on the website. Out here in the NW we are waiting for Hardie to come out with 7/8" Harditrim. Apparently that product has been introduced to the SW market, but they are not selling it in the NW - for some reason...
