fiberglass ladder recoating
PeteDraganic | Posted in Tools for Home Building on December 13, 2006 06:29am
I have a fiberglass extension ladder that stays on my truck all year long.  The protective finish has worn away and when I use it bare-armed, I itch like crazy because the glass fibers get into my arms.
Anybody ever respray one of them?  I’ve a buddy with a body shop, I should probably have him spray some clear on it.
http://www.petedraganic.com/
Edited 12/13/2006 10:34 am ET by PeteDraganic
  1. GregGibson | Dec 13, 2006 07:26pm | #1
    OK, Pete, I'll say it before anyone else does . . . .
    Get an Engineer's stamp on it ! ! !
    ; > )         Greg
    MarkH | Dec 13, 2006 08:17pm | #2
    Spar varnish it.
  3. Southbay | Dec 14, 2006 06:46am | #3
    Have your body shop bud recoat it with epoxy resin.
    You could first add some cool stickers and yer name, company name, girlfriend's name...OK, maybe not your girlfriend's name.
    Better than new - maybe a bit heavier.
      PeteDraganic | Dec 14, 2006 06:53am | #4
      yeah, my wife really hates when I write my girlfriend's name on my tools.
  4. alwaysoverbudget | Dec 14, 2006 07:28am | #5
    just shoot a couole coats of clear lacquer on it and that will stop the itching,plus they will be shiney!larry
  5. Piffin | Dec 14, 2006 01:40pm | #6
    I'd be down to the auto body shop reading labels on the finish ooatngs.
    no, on seccond thought - by time a FG ladder is shedding that bad, I'd leave it at the dump so nobody would get hurt on my insurance,
  6. danski0224 | Dec 14, 2006 02:15pm | #7
    If the UV has stripped the gelcoat, then I would seriously consider scrapping that ladder and buying a new one.
    Fiberglass ladders are damaged by leaving them outdoors on the truck all the time. If anyone knows of specific OSHA or MFG guidelines for replacement, I would like to know what they are.
    I do know that stickers, paint, tape, etc applied to a ladder after it is manufactured violate OSHA guidelines.
    Fiberglass will fail without warning and catastrophically.
    It isn't worth it.
    Oh, and do yourself a favor and buy an American made ladder and not one of the Chinese ones at the big box stores. Check the side thickness even on the same weight capacity ladders between USA/Chinese made and you will understand.
  7. User avater
    skip555 | Dec 14, 2006 06:12pm | #8
    I have the same problem with mine , in fact I have to wear gloves when I use them
    I have a PDF I downloaded from WERNER on how to recoat them
    it includes how to prep and suggested coatings .
    If you would like I could email you the PDF .
    its called fiber bloom and they call it a aesthetic condition , not a structural one so no need to trash the ladder
    1. voice8313 | Jan 05, 2012 12:38pm | #10
      If I can get the PDF to recoat ladder or the link to recoat ladder I would appreciate it very much.
      Thanks for your time
      TJ
      1. calvin | Jan 05, 2012 12:41pm | #11
        voice
        the posts are 5 yrs old.  You might try to go to Werner Ladder and hunt up the information using the descriptions provided above.
        best of luck.
  8. BillBrennen | Dec 14, 2006 07:08pm | #9
    Pete,
    Whatever you use, it should be clear so the ladder is inspectable, and should have UV inhibitors so the sunlight cannot eat the resin holding the fibers together. Epoxy is not good for UV. The spar varnish sounds good. Woodworking lacquer will fail very rapidly outdoors and the solvents could hurt the ladder.
    Following Werner's recommendations (noted in earlier post) sounds like the best plan IMO.
    Bill
  9. roddymcc | Aug 30, 2014 01:31pm | #12
    Yeah, I know it's an old thread ...
    ... but the PDF referred to is the Werner Fiberglass Ladder Technical manual
    http://us.wernerco.com/docs/userguides/gm6070-fg-techmanual.pdf?Status=Master
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
