Filter/Regulator/Lubricator for Nailer
Bought a Hitachi NR 90 AC3 nailer, they say to use a filter/regulator/lubricator unit at the nailer. What do you use and recommend?
Thanks —
— J.S.
Thanks —
— J.S.
With the right approach, you can restore old hardware—whether through soaking, scrubbing, or polishing—giving it a fresh look while preserving its original charm.
I just oil the gun, four drops in the morning and 3 more after lunch if I am using the gun a lot, say sheathing for instance. Most days I just oil the gun in the morning with moderate use.
mike
I`d go with the filter /regulator to get dry air to the gun and oil the gun directly as mentioned. Several drops a day is all that should be needed and if you ever need that air line for any other operations it won`t be full of oil and sludge. Don`t skimp on the filter quality. Water is your enemy here.
