HO has asked me to refinish a deck that has PT frame and rails but is decked with teak. Frame and rails are done with transparent stain. HO says the teak needs to be oiled. I have done plenty of painting and staining in my day, but pardon my ignorance, what do you do to teak? Location is suburbs of NY, deck is two feet off the ground, mixed sun and shade.
Framing the floor inside a crawlspace foundation keeps a gable-end addition close to grade.
You should only treat a teak deck with teak oil. (NOT 'tung' oil, which isn't the same sort of thing at all, but you'd be surprised how many people confuse the two.)
Teak is a naturally oily tropical hardwood. It stands up to water and sun so well that it became the wood to use for ship's decks. It also has the particular quality of not being slippery (or 'as slippery' as other woods) when wet, which is a nice feature for a deck one can assume will be wet a lot of the time.
If you can't get teak oil at your local paint supplier, you can find it from a number of suppliers on the net. Run it through Google. It's not cheap, but it's the only thing to use on teak. If your client can afford to have the deck make of teak in the first place, he can afford the teak oil to revitalise it.
Figure on flooding it with the oil when it's nice and warm, and letting it soak in for a while. If it soaks up everything you pour on, add more until it stops soaking in. Then wipe down, let dry some, and buff with a floor polisher.
If the deck's been neglected and is badly dried out, it'd be a good idea if you went back after a week or two and repeated the oiling process. The rule for oil finishes on furniture is:
For a deck, you can ease off on that some as you're not looking for the really deep luster finish you want on furniture. But giving the wood a chance to soak up what you've fed it before you try to add more is still a good idea. Buffing the deck will avoid any issues with residual surface stickiness collecting bugs and dirt.
Explain to the homeowner that if he maintains it on an annual basis, the deck will drink up much less oil each time and last longer.
Dinosaur
foolish men call Justice....
Go to a local Marina and see what they recommend as the latest and greatest. Minwax must make something, and as in another post be sure it's for teak.
Do not use anything Minwax makes for this unless its truly Teak Oil, and it'd be doubtful that Minwax would have teak oil, it'd be some cheap azzed imitation!
Do what Dino says. I agree that you don't have to apply as much as if it were a fine piece of furniture but let it soak up as much oil as it can handle.
