A friend of mine would like me to tape and mud his garage walls and ceiling then paint it all. This is a 2 1/2 car garage, with the house and garage being built in 1973. The dry wall has never had paint on it and 5 sheets in the ceiling need replaced. My concern with finishing the dry wall is that its to old to work with. I am leaning words suggesting to him that I put OSB on the walls and ceiling and paint it. Any thoughts on this? Thanks for your help.
From plumbing failures to environmental near disasters, OHJ staffers dish on our worst and best moments.
Tape and float a wall and see what happens, if the paper hasn't seperated its good, its a garage and sounds like your customer just wants it to look better with as little expense as possible.
*There are a number of products out there for stabilizing older drywall. Smooth wallpapers either glued or epoxied on; and, mix Weldbond with water (about 4:1 I think) and painting it on are two that I've actually seen used. When they painted my neighbour's garage (also unfinished drywall that had been sitting about 8 years at the time), the painter just mixed up a bunch of left-over paint, thinned it down, and painted a "soak-in" base coat on the wall to consolidate it - looks like it worked too.
