user-7598022
| Posted in General Discussion on
Hi everyone,
I have a question that I’m hoping you can assist me with. A few months ago I poured a concrete slab with pex pipe embedded for radiant heating.
So here is my dilemma. As an after thought I decided that I would like to have a wet room in my bathroom, instead of a regular shower, the problem is that I need to slope the floors, but, I can’t do any digging because of the pex in the floors. How can I slope for drainage without digging?
What options do I have?
Now this is a new build, so I already have PVC running under ground, and there is a square hole in the floor that I believe is for drainage purposes.
The sloping of the floor is what I am not sure about. Thanks so much for your help. Have a blessed day.
From not venting your bathroom to not venting your siding, understanding how things go wrong is the first step to getting them right.
Your only option is to install a curb and slope from there.
Another (perhaps less desirable) option would be a small step (or steep ramp) up at the entry door of the bathroom with a mud set (or similar) sloped floor inside the bathroom (as necessary) to your drain. In any case, I believe the code requires you to slope your "shower" floor 1/4" per foot min. and 1/2" per foot max. from the outer extents of shower to the drain.
