“Finishing Basements by Arnold & Guertin
An article titled as above appeared in FH #132(?) concerning wall systems which allow water vapor to pass thru into the basement. The graphic shows unfaced fiberglass insulation in the wall, a rather short one at that. Now for my question:
If you are installing the described wall system, how does one go about supporting the insulation in a 96″ high wall?
Can another type of insulation be used instead of batts?
I am all ears,
thanks,
dlb
