In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Fireplace demo – what to do with chimney
SpitfireXI | Posted in General Discussion on October 16, 2005 12:53pm
Hi all,
As part of constructing a new kitchen in the former family room I have demolished the interior “cosmetic” portion of my fireplace.  The chimney itself has to stay as it also serves the furnace and hot water heater.  So I have no plans to demolish the exterior portion of the chimney.
I have two questions.
First, any suggestions on how to seal of the flue from the inside?  I plan to stuff fibreglass insulation in the fireplace cavity, then frame it over.  But should I do anything to seal off the flue before adding the fibreglass, or just make sure its closed tightly and insulate the cavity?
Second question, what should I do with the cavity inside the liner, which is a masonry liner?  Should I just leave it be?  Fill it with anything?  I have this vision of dropping a couple of garbage bags full of stryrofoam chips down it LOL!  And as for the top of the chimney, should I seal it in some way to keep out the rain and birds, or should I just leave the current metal chimney cap?
looking forward to your suggestions,
Charles
  1. Piffin | Oct 16, 2005 01:19am | #1
    Well a bit more info is needed here.
    on what floor level are the other appliances relative to this FP?
    What size are each of these flues?
    Do you mean to say that the appliances and the FP all shared the same flue within the chimney?
    1. SpitfireXI | Oct 16, 2005 03:41pm | #2
      Fireplace is on the main floor of a 2 story house.  The furnace and hot water heater are in the basement, pretty much right underneath the fireplace.
      There are 2 flues within the chimney - one for the fireplace and one for the furnace and HWH.  Furnace and HWH are oil-fired, though I am thinking of converting to electric for the HWH.
      I am not sure exactly what size the flues are.  I'm not a big fan of being on the roof and have never been up there to measure them.  I think the FP one is a little bigger, maybe 12" x 8" or so.  The other one is more square, maybe 10" x  8" or 8" x 8".
      I hope this clarifies things enough.
      1. Piffin | Oct 16, 2005 04:32pm | #3
        Sounds right. I'll have to assume then that the guys who installed the appliances made sure they were sized with the flue right.And since the flues are separate, just seal offthe FP flue. Cut a hunk of foam to fit tight and use spray faom in a can to seal it in place. Then go up on top with a slab of bluestone to set over the top end, making sure that you don't close off the wrong one. This cap is not absolutely necessary but it is always good to keep some of the rain out
Forming Foundation Walls
In the first episode of FHB House Kansas, Travis and Joe of Catalyst Construction walk through details of their foundation walls.
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
  • Get Stunning Views With Folding Glass Doors
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Step-by-Step Install Prehung Exterior Doors
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
