fitting crown molding
terry57 | Posted in Construction Techniques on February 21, 2008 09:13am
I am getting ready to install crown molding on my kitchen cabinets. They are open at the top (no soffit). The problem I see is, how do I deal with that outside corner return to the wall? The front stile sticks out approx. 3/16″ from the face of the side panel creating a reveal. Am I supposed to put a filler under the bottom edge of the crown or do I notch the crown so that it will fit flat to the side of the cabinet face? Appreciate any thoughts here.
    JDRHI | Feb 21, 2008 09:33pm | #1
    MOST crowns I install to cabinetry are actually installed to a flat stock that sits on top of the face frame which accomodates the reveal you are concerned with.
    If your crown application doesn't include this feature, you could consider coming up with your own.
    Or maybe you have a piece of filler strip left over from the cabinet installation? You could rip a piece of that to fill the void along the top of the side panel.
    I've seen it notched....not crazy about it.
    Beware the bikini clad female.
    She may be interpreted as offensive.
      bp21901 | Feb 21, 2008 11:53pm | #2
      You know, I did put the nailer stock on top of the cabinets as you mentioned and for some reason it never occurred to me to raise the bottom edge of the crown to sit on top of the face frame - DUH. Lesson learned for next time.Anyway, my crown is about 1/8" down from the top edge of the cabinet and I notched the reveal on the side so that crown is flush with the side of the cabinet. I have 3/16" thick trim against the wall also so it matches the reveal on the side edge of the face frame. Maybe I'm not picky enough about such things, but it doesn't hurt my eye looking at it.
    hammer1 | Feb 22, 2008 12:06am | #3
    There a few ways to handle it. A common one is to order skins which are attached to the ends of cabinets that show. These bring the end fairly flush with the faceframe overhang. Another way is to make a filler that is that thickness. Install it so it is flush with the bottom of the crown or leave it down for a reveal. You can rip it out of a piece of filler and keep the finished edge down where it will show. On a low budget job, the faceframe will get notched, not the crown molding. If the frame doesn't stick out too bad, this isn't all that noticeable. Only takes a couple of whacks with a sharp chisel.
Kimberley Robles, Decorative Concrete
In this interview, Kimberley talks about the importance of proper training, current concrete trends in the Bay Area, and the history of racist housing policy in San Francisco.
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
