I will be building an addition to my house that will be used for my wife’s quilting business. She has a large (14′ long) quilting machine table with a large machine she uses for quilting. The machine creates a great deal of vibration so I am going to have the quilting room on the ground floor of the addition and that floor will be a poured concrete slab. I want to make a framework with treated 2X4 studs placed on the 4″ edge on 16″ centers. This framework will be glued with construction adhesive to the concrete. I plan on placeing styrofoam insulation in the voids between the studs to insulate the floor.I’ll screw 3/4″ plywood onto the studs to finish the floor. I will pour the concrete over a plastic sheet vapor barrier. I’ll put a carpet with a pad on top of the plywood to complete the floor. Will this work? If not, what are the problems?
Fred
What you are wanting to do will work great, but if it were me I would insulate under the slab this way you will save money by not having the lumber expense and also you will not lose any ceiling height. You could use a 2" rigid form for this application. Also you can anchor the machine directly to the concrete.
Edited 7/25/2003 8:00:48 PM ET by byoung
