In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
floor vapor barrier 4 basement bath
mem21 | Posted in General Discussion on October 26, 2008 02:25am
I am having a new bathroom installed in my existing basement. I just had the rough-in plumbing inspection done (passed thank God!). As the plumbing inspector was leaving he said “Make sure you call for the ‘Vapor Barrier’ inspection before you lay the concrete in the floor.”
Basically what I did was bust up the concrete floor and dig down so the plumber could install the waste pipes. I had planned on putting back some of the excavated dirt, then gravel, then concrete. I did not know I needed to put a “vapor barrier” down. The house is 90+ years old, I doubt there is a vapor barrier under the rest of the basement floor.
My questions are:
1. Do I need a vapor barrier? If so, what thickness and what product/brand?
2. My trench has a 90 degree turn, how do I seal where the two pieces of plastic meet?
3. What is the correct installation steps that need to be done?
Thanks for the help!
  1. fingersandtoes | Oct 26, 2008 04:41am | #1
    Bed your pipes in sand fill. Use the gravel you excavated to get to slab height when compacted. Lay down 6 mil. poly. Seal with red tuck tape. Provide gasket at pipes to isolate from slab.
    Or to be sure, ask your BI what he'd like to see.
    edit for sp.
    Edited 10/25/2008 9:42 pm ET by fingersandtoes
DeWalt Recalls 12-in. Sliding Compound Miter Saws
Purchasers of certain models should stop using the saw immediately and contact DeWalt to receive a free repair kit.
  • Healthy Cash Flow Management
  • Podcast 484: PRO TALK With Color Consultant Paula Gaull
  • Using Liquid Flash at a Wall-to-Foundation Connection
  • Forming Foundation Walls
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Outdoor Projects
    Buy Now
  • Pretty Good House
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
