I,m about to install an ash strip floor. It,s a renovation.we,re living in the house.in order to limit enviromental impact to the family, my thought is to finish the floor in the following way: Sealer coat with traditional solvent based polyurethane,following coats with water based. I would go with water base all the way except that I like the rich color change that happens with oil based products. I would rather not stain with a water based stain, i prefer the natural color spectrum. Any thoughts on using the finishing products in this way?Thanks for any comments or opinions.
Find online articles on A Fine Finish for Wood Exteriors; Furnace to Heat Pump Retrofit; Windows Before Housewrap?; More Building Science Mistakes to Avoid; EV Chargers and much more.
My feeling is that not much will even stick to solvent-based polyurethane. See what others have to say, but...maybe at least test it on a scrap or something before doing the whole floor. I'm of the opinion that oil and water don't mix.
Edited to add: You may try posting your question on Knots--the woodworkers web site. They probably have a lot of experience with various finishes and compatability. Good luck.
Edited 9/1/2004 8:24 pm ET by Danno
you don't say how much square footage is being coated the more there is, the more chemical gasses off to home environment it's not health food i coated a beam & deck ceiling w oil base poly some years ago, plenty of windows open, then stayed in the house woke up early am hacking and wheezing trained professional that i am, finally read the label on a can of poly "can cause chemically induced pneumonia" left the house, was ok few hours later...
look into "emulsion coating" by basic coatings it's a hybrid oil & Water borne which dries in 2 hours, very low odor similar to all the waterborne products oil content gives it some of the oil tone you're looking for self-bonding, it does not require a sealer coat like most water bases, so 3 coats are all wearcoats open windows and let house vent off after drying usually sand and first coat on first day, apply 2 coats on second day
might have problems mixing chemicals; oil, then water as you mentioned mfg's all recommend against mixing different brand products seen it done, sometimes gets opaque look, have seen a couple w surface going bad... there's also a water base tint product you can apply first to sanded floor deck, gives waterborne poly the look of oil haven't used it in a while, will try to remember the name, maybe someone else knows it offhand?
