Flush beam install
user-6785380 | Posted in General Discussion on June 23, 2020 05:40pm
I have a project where I will be removing a bearing wall and replacing it with a flush beam LVL, normally a no-brainer. Engineer is spec’ing beam. My concern is that the homeowner wants the beam to be installed bearing on two existing 2×4 walls, one at the outside of the house and one that is the middle main load bearing wall. The beam will be on the first floor of a two story house with a stick framed roof. The LVL would and then blocked and braced down to the basement, beam and foundation as usual. The rub is that the homeowner wants to avoid having any posts protrude from the existing walls where the two new point load will be created. There is a finished second floor above. The beam has an approximate span of 16′ and, the ceiling joists are 2x10s on 16″s.
My concern is whether there will be enough room to whack the LVL into postion over those two existing walls, or whether the LVL would need to be notched so dramatically to get it in place that it would be weakening the beam too much. I’m also not sure if 3 1/2″ (I’d kind of be shocked) would be enough bearing surface for the point loads created by the LVL, but I suppose that would be for the engineer to determine. Anyway, simply put as anyone installed a long(ish) LVL over the top plates of two exiting walls successfully?
Thanks for any advice…
New House, Old Shell
A full gut remodel brought new life to an 1821 home that had undergone several misguided renovations.
  • Monitor Both Outdoor and Indoor Air Quality
  • What You Need to Know About Installing Steel Siding
  • Podcast 570: PRO TALK With Project Manager Jeremy Hess, Part 1
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
