From the current issue article by FredL:
Low-expanding Pur-Fil foam and Pageris gun distributed by Todol Products Inc., (508) 651-3818, cost: foam, $15 per can; gun $111
Sounds like it is BIGTIME better than using the foam-in-a-can “STUFF”.
Sometimes the “STUFF” can doesn’t stop flowing and I’ve never been able to use a half-used can a day after it’s first use. The propellant escapes.
Is this gun (or a smiliar one) available for less than $111.00? It is kinda steep for a homeowner.
Phil
Since my whole crew is comprised of me, I haven't broken the cheapie yet. The Pageris is nice, but mine had a bad seal or something and set up. The factory hasn't sent it back yet after 2 months. If you do buy one - ALWAYS LEAVE THE CAN ON!!! Don't even consider buying the cleaner and taking the can off when not in use.
-Rob
*PhilI bought one for a window job about six months ago and have been using it ever since. Its is quicker cleanera and reusable. Again never take the can off the gun. even if you dont't have a new can and the old can is empty leave it on until the new one ariveskevin
Sounds like it is BIGTIME better than using the foam-in-a-can "STUFF".
Sometimes the "STUFF" can doesn't stop flowing and I've never been able to use a half-used can a day after it's first use. The propellant escapes.
Phil
