Hi all,
I am planning on replacing the decking of a covered front porch on a 1915 craftsman in Seattle. I am considering using t&g fir and plan to coat all exposed surfaces prior to instalation and then sand and paint the deck.My questions are;
1)any suggestins for material besides VG fir or hemlock?
2) what expansion / contraction should i expect along the length of the boards and how do I allow for this. I planned to butt the end grain against a 3 1/4″ rounded over trim peice that would be exposed to the side walk. Do I bang it up tight or leave a gap.
3) any good ideas for getting all the boards to the exact correct length and getting a nice straight line along the end grain portion of the decking. Due to pillars I won’t be able to lay them long and trim them later all at once. I planned to butt them up against a removable straight edge.
4) anything to treat the boards with besides a good oil base primer?
5) any old FHB issues that you can remember that deal with this?
any other info or questions are welcomed.
Thanks in advance.
Dave E.
I did the same thing to my porch last fall. VG doug fir is the way to go, I think.
No. Fir is the way to go.
2) what expansion / contraction should i expect along the length of the boards and how do I allow for this. I planned to butt the end grain against a 3 1/4" rounded over trim peice that would be exposed to the side walk. Do I bang it up tight or leave a gap.
Bang it tight. There is little or no movement along a boards length.
3) any good ideas for getting all the boards to the exact correct length and getting a nice straight line along the end grain portion of the decking. Due to pillars I won't be able to lay them long and trim them later all at once. I planned to butt them up against a removable straight edge.
If you really can't run them wild and cut at once, then perhaps you can rig up some kind of temporary board to butt into. I can't see your project, so it's hard to say.
I used an oil based self priming porch floor paint from Diamond Vogel.
Dont' know.
Thanks in advance.
Dave E.
