front porch floor finish
| Posted in General Discussion on September 26, 2003 08:40am
I have a house in Seattle with a covered front porch. I rebuilt the entire porch and decided to reuse the fir flooring.  As I mentioned the porch is covered but winter storms will often blow water onto the SW corner and on the South facing front edge. I planed off about 1/32 to remove some of the weathered wood and reinstalled the tongue and groove flooring (5 foot long). I looked and looked for a solution but the best thing I could come up with was a penetrating deck stain with some UV protection ~Dalys, a local paint store. (I opted for clear since the porch does not get that much direct sun) I am concerned that the re-used flooring will have places where water can get through. (I have a exterior grade plywood sub floor with tar paper over it)
Should I have used another finish? Should I put something else down on top like a wax or varnish?
Thanks for you help
John
  1. YesMaam27577 | Sep 26, 2003 04:27pm | #1
    I'm not at all familiar with construction techniques in the northwest. But in my old stomping grounds of Ohio, and here in Carolina, it is not common to use plywood subflooring under a porch floor. When T&G porch flooring is laid, it is laid directly on the porch floor joists.
    Sounds to me like the porch was built so that it can be easily converted to living space? If that's the case, then maybe you should start planning those walls.
    No finish will be truly effective at stopping water, when the surface is as exposed as yours is. Marine spar is OK, epoxy is better, but keeping the water off in the first place is best.
    Vast projects should not be founded on half vast ideas.
  2. Piffin | Sep 27, 2003 07:04am | #2
    What you should have done is lay the flooring with the bottom side exposedd to dry when it gets wet. Water will now be trapped between the fir bottoms and the tarpaper. I'll give it five years. Consider this a practice run. We all learn from these oops.
    Luka | Sep 27, 2003 01:13pm | #3
    Very nearly under the aurora bridge, near the UW, is a place called docs. (Was there the last time I was in seattle.)
    They sell boat parts, finishes, you name it, for boats. Check there for a marine finish.
    If it'll stand up to floating in the bay, it'll stand up to a rainfall or 6.
    Quittin' Time
    Edited 9/27/2003 6:14:49 AM ET by Luka
Episode 1: Drywall Tools for the First Coat
Learn about mechanical and automatic tools such as the taper, the compound tube, and the banjo to make your drywall job better and easier.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
