I’m building a 28’x24′ heated garage that has 4′ frost walls built with ICF’s. (3 1/4″ insulation on both sides of the concrete.) Will I benefit enough from putting 2″ insulation under the slabto make it worth it? The garage will only be heated to 50 degrees or so. Thanks!
Keeping HVAC systems within the conditioned enclosure can be tough without a basement; one option is to use plenum trusses for the roof, which offer a space for equipment and ductwork.
